In my '72 bug, dash. I have the square plastic box that has the brake warning light in it and another hole right next to the warning light. What goes in that other hole????
My other question is: Is there a light that goes inside of the emergency flasher knob?
Empty hole
- harryset
Empty hole
'72 Standard
"I am the proud owner of a "Hoover Bit".
185 60's, EMPI disc kit, EMPI 2 1/2" dropped spindles on the front.
185 65's and stock binders on the back.
SecondSkin - Damplifier Pro and Luxury Liner Pro for sound control.
Re: Empty hole
1 dont remember. Maybe check samba for an owners manual.
2 yes there should be a bulb.
- Marc
Re: Empty hole
That's where the control switch goes for the ventilation fan (if equipped). Standard Beetles without the vent fan should have a black plastic plug in the hole.
Vent box w/fan:
http://www.thesamba.com/vw/classifieds/ ... id=1154379
Switch:
http://images.thesamba.com/vw/classifie ... 963555.jpg
Plug for 10mm hole:
http://www.bughaus.com/Unavailable%20it ... 857490.htm
The bulb inside the hazard switch is a sub-miniature wedge ("grain of wheat") #2721. #2723 is the same size but brighter.
Vent box w/fan:
Switch:
Plug for 10mm hole:
- harryset
Re: Empty hole
Bummer, I don't have to worry about the blower hardware, but my flasher knob doesn't have a receptacle for the bulb.
'72 Standard
- harryset
Re: Empty hole
Never mind, I can see the contacts way down inside of the knob assy. Now to find some bulbs.
'72 Standard
- harryset
Re: Empty hole
Ha! I found both 2721's and 2723's on the shelf at the local auto parts store. I'm always surprised when I find the right stuff, locally.
'72 Standard
