Piggy backing grounds on relays?
- panel
Can you Piggy back grounds on relays.
- perrib
Re: Piggy backing grounds on relays?
You can but if the wire attached to ground on the body or battery to the start of the piggy back connections breaks all the relays become inoperative not just one.
- Dale M.
Also as long as conductor gauge is sufficient to supply enough current to operate relays....
Dale
Dale
- panel
Thx you two.
To help you figure your wire sizes, common DIN relay coils typically use about 130mA.
Rule of thumb, your ground should be of the same gauge as the positive wire(s) it is supporting... if that helps any.
