Alternator bearings
Turbo_Manx_Maniac
Alternator bearings
Post by Turbo_Manx_Maniac »
Anyone know if replacement alternator bearings are avail, and if so where? AL82N.
Mine was a new Bosch, 1.5 years old and both front and rear bearing have excessive play in them.
I accidentally Googled my Twitter. (And I liked it)
Dale M.
Re: Alternator bearings
Post by Dale M. »
Turbo_Manx_Maniac wrote:Anyone know if replacement alternator bearings are avail, and if so where? AL82N.
Do not know of any parts houses, but if you have numbers off bearings any "commercial bearing house" (check phone book) should be able to get bearings for you or convert numbers to another brand of bearings....
Dale
supaninja
Post by supaninja »
viewtopic.php?f=14&t=140387
Turbo_Manx_Maniac
Found them on TOS.
SKF Brand
Mfr Part number 6203 2RSJEM
Mfr part number 6202 2RSJEM
Lots of local shops have them.
Suprised these bearings went out so quick, it was a 1.5 year old Alt Bosch. Would have expected that with a China alt.
supaninja
Post by supaninja »
how tight is your belt?
Post by Marc »
Fan imbalance is most often the culprit. I wouldn't trust this one without having it checked. Look closely at each fin, the factory welds little weights to them when balancing - if one falls off you should still be able to see evidence of where it was.
OEM P/N for bearings is 111 903 221A
Turbo_Manx_Maniac
Marc wrote:Fan imbalance is most often the culprit. I wouldn't trust this one without having it checked. Look closely at each fin, the factory welds little weights to them when balancing - if one falls off you should still be able to see evidence of where it was.
The belt was the normal tightness, not overly cranked. I did check the fan last night, it's not wobbly but it certainly could be out of balance, there was quite a bit of dust from off roading on it. Did not see any signs of a weight falling off, but with the dirt going in there the marks could have been sandblasted off.
Still, the last Alt lasted in the exact same conditions for over 10 years.
