hazard switch question?
Moderator: 2088 bob
VW_Man_87
Post by VW_Man_87 » Fri May 21, 2010 7:44 pm
hello electronic gurus
i am wondering on how to wire up a toggle switch (one with the racing cover) with an led light for it also just like original switch, for the 4 way hazard lights and would like to have a diagram? for when i go to rewire my 74 ghia.
and also how can i wire two of the same switches for the low and high speed of the wipers? diagrams would be nice.
i have the headlights figured out for the toggel switch along with the marker and license plate lights.
and for all of these switches i will be using relays that wont be a problem.
thats all for right now.
thanks
_-Mad-Max-_ aka Jeremy Perry
im in need of a new front clip for my 74 ghia, i dont care what year its from but i need one in order to fix my front end, can anyone help out?
Speedy Jim
Re: hazard switch question?
Post by Speedy Jim » Fri May 21, 2010 8:59 pm
You can do it with a DPDT toggle and a 2P relay.
One half of the toggle will switch "+" (49) between #15 and #30.
The other half of the toggle can operate the relay.
The relay, in turn, will close #49a to both "L" and "R".
Simplified diagram of what the stock Hazard switch looks like:
This is what your wiper circuit looks like now:
If you can live without the "Park" feature when you switch off,
a simple SPDT center Off toggle will do it.
Just switch 53a to either 53 or 53b.
Speedy Jim
http://www.nls.net/mp/volks/
VW_Man_87
Post by VW_Man_87 » Fri May 21, 2010 9:09 pm
could you give me a link to some of the parts, or a location like a flaps. to get the dpdt racing cover toggle swtich and 2p relays?
and what is the park feature do?
Speedy Jim
Post by Speedy Jim » Fri May 21, 2010 9:42 pm
http://www.wiringproducts.com/contents/en-us/d130.html
maybe #7300002
They have a safety cover too.
SP relays:
http://www.wiringproducts.com/contents/en-us/d36.html
could use 2 of 'em.
DPDT:
http://www.hosfelt.com/contents/en-us/d111.html
#45-689
Great relay forum:
http://www.the12volt.com/installbay/for ... .asp~FID~5
Park refers to the wiper motor automatically running until the blades are at the rest (Park) position.
It makes the circuit a lot more complicated.
SJ
VW_Man_87
Post by VW_Man_87 » Fri May 21, 2010 10:06 pm
ah ok, thanks for the info.
just curious can the hazards be hooked up with a spst switch?
Post by Marc » Fri May 21, 2010 10:08 pm
VW_Man_87 wrote:...just curious can the hazards be hooked up with a spst switch?
If it was that simple, don't you think Jim would've said so? You could use a SPST switch that did nothing but cross-connect the LH and RH lights, but you'd still need the ignition on (and the t'signal switch flipped up or down) to have hazard flashers.
As for the wipers, if you can find a two-pole, triple-throw (DP3T) switch that'll handle the current you can duplicate all features of the stock switch, including park.
An alternative arrangement could use a common DPDT switch along with a SPDT relay.
The link at the bottom is to a diagram for a DP3T switch on a `67-`71 wiper motor, for the benefit of anyone contemplating doing this to an older car.
VW_Man_87
Post by VW_Man_87 » Fri May 21, 2010 10:27 pm
now could i use two spst switches for the wipers?
Post by Marc » Fri May 21, 2010 11:01 pm
Again, if it was that simple......
VW_Man_87
Post by VW_Man_87 » Fri May 21, 2010 11:11 pm
ok could you do it this way
hot into 2 switches one out to the low and one to high, kinda just like the on-off-on switch
Post by Marc » Sat May 22, 2010 12:06 am
What would happen if you inadvertently switched them both on at once? I don't know, but I doubt that it would be good....and it's certain that you would at some time or another. Just break down and get a SPDT/center-off switch, they aren't that expensive.
VW_Man_87
Post by VW_Man_87 » Sat May 22, 2010 12:44 am
ok on the dp3t switch can you find me one that i can use the safety cover on, as i would like to achieve the cockpit of a plane switch looks?
thanks
Jeremy
VW_Man_87
Post by VW_Man_87 » Thu May 27, 2010 6:15 am
i have a question, i would like to add a toggle switch on the main feed wire to the key and was wondering what amperage i would need for that switch? kinda like a cut off switch for the key so i can hide it under the dash per-say...
i would like to have a key operated switch but i would like to know how much amps runs through that main constant line then when the key is on to everything else?
a 2 pole universal key switch, like on and off with a key would be perfect for me, like from the FLAPS.
thanks
CBDZ
Post by CBDZ » Fri Apr 03, 2015 2:14 pm
I just wanted to report back on this. Everyone here is such a huge help. I have just wired my wipers on my Fiberglass Buggy as shown here...
It works perfect!!!
My Car Details:
Fiberglass Buggy on 1973 Chassis.
1904 cc
Megasquirt (MS1 with 3.57 board) Fuel Injection: German Intake Plenum, CB Performance End-Castings, Ford Escort Throttle Body with custom Adapter, MS controls Wasted Spark Coil Pack
