Basically, what i tried to convey in the picture (i know its horrible, i tried) is to plug in between the first setting on the stock wiper switch and the motor, a circuit that uses a rheostat to alter the current to a flasher type relay (turns on and off according to incoming current) which then controls a larger relay that then controls the power from the stock wiper switch to the motor.
The operation would hopefully be as follows: Press a little green button, which activates the intermittent feature, and interrupts the first speed of the wiper motor to go into the circuit, then back out to the wiper motor. You then can adjust how fast you want the intermittant wipers to work by turning a knob, up to a maximum frequency of just below however long it is between parks on the wiper motor.
I need some help with finding out a very slow flasher type relay, with seconds between flashes instead of fractions of seconds, and finding the value of rheostat i would need. I know i can experiment, but i want to get this right before i go raid radio shack for a handful of rheostats and relays.
