Schematics, diagrams and shop drawings.
Moderator: 2088 bob
MNAirHead
Post by MNAirHead » Wed Jan 02, 2008 12:40 pm
MNAirHead
Post by MNAirHead » Mon Feb 25, 2008 1:05 pm
panel
Post by panel » Fri Apr 04, 2008 8:49 pm
Anyone have a '72 Beetle wiring diagram for me to have a look at. This car I'm working on has 12 fuses on the block.
-Marc.
Subaru JDM EJ20 Turbo bus
shopteacher
Post by shopteacher » Fri Apr 04, 2008 11:10 pm
once again TIM.. you have the info we need!!!
MNAirHead
Post by MNAirHead » Sun Apr 06, 2008 10:51 am
That's why we're here.
MNAirHead
Post by MNAirHead » Mon May 05, 2008 12:35 am
MNAirHead
Post by MNAirHead » Fri Jul 11, 2008 9:49 am
rickosuave1987 wrote:If you use a relay to make the fuse panel hot with the switch ths is how it works and how I did it in my car.
(the panel in the middle)
Post by david58 » Fri Oct 31, 2008 4:44 pm
63 US Model Speedo Wiring
Typical Horn Wiring
3 switch master cylinder wiring
type3_61_fuses
Starter wiring
Bosch fog light relay wiring diagram
Early bay turn signal wiring diagram
Baja Bug Wiring
Bus Emergency Light wiring from 8/1965
Fuel pump wiring
Speedometer Wiring Diagram for later Super Beetles and Convertibles.
Thing wiring diagram
Dual Battery wiring
EFI wiring T3/4
bug wiring
1966 1300 Type 1 wiring diagram
Noco battery isolator wiring diagram
flyingCoyote
For charging a second battery while protecting the first from discharge (camping, radios, etc)
71 SB Wiring Diagram
This is a modified wiring diagram showing the alternator wiring for a conversion from externally regulated alternator or from a generator
Here is a short and sweet help with wiring a genrator and alternator. it includes the regulator wiring diagram
Image Image
Portion of the 67 bus wiring diagram showing the engine compartment
Full lifesize wiring diagram
Post by david58 » Wed Nov 19, 2008 4:08 pm
1965 Type 1 Fuse Block
MNAirHead
Post by MNAirHead » Thu Nov 20, 2008 12:14 pm
Great stuff David - thanks again.. you have the coolest library of this stuff.
Post by david58 » Fri Nov 21, 2008 6:59 pm
Post by david58 » Thu Jan 22, 2009 4:29 pm
Canuck70Ghia wrote:Here are some pictures of the EFI system and various pieces/parts:
Post by david58 » Sun Mar 29, 2009 8:03 am
Note H3 is the door ajar buzzer
Post by david58 » Fri Apr 10, 2009 6:06 am
Standard Tail light Wiring 73 - 79 Elaphant feet. Nice Diagram Speedy. :wink:
shopteacher
A-arm total car Suspension EXPLAINED
Post by shopteacher » Sun Apr 19, 2009 11:11 pm
http://www.honkernet.net/AHS/department ... ension.htm
Rear pivots line up to point at either the differential or a central part on the transaxle (also known as the THIRD member)
straight line off the steering arm of the
spindle points to the same point on the trans that the rear pivots point at.
Steering arm length is determined by how much response you require in your steering wheel--shorter arms turn faster
Front spindle to rear axle length should be the same on both sides and camber set equal before adjusting toe in/out, set rear toe first
Bump steer can be eliminated or at least minimized by making sure all the arms and tie rods are parallel and the inner heim joins line up
Control arm attachment points line up with rack mounting points
and intersect on the center line of the chassis
