Empi 40mm IDF Center Mount Carb Complete Assembly
videoguy009
Post by videoguy009 » Sun Mar 08, 2015 4:30 pm
Empi 40mm IDF Center Mount Carb Complete Assembly.This includes the 40mm idf carb,Deluxe center mount manifold and heat risers from aircooled.net(200.00 value) and intake castings.You will notice I replaced the manifold boots to a heavier rubber tubing which works very well.I was tired of the stock ones splitting and leaking.This setup was pulled to replace it with dual carbs.The total investment is close to 500.00 but I am asking 200.00 plus 35.00 for shipping to Canada and the USA.Just to note that this carb has factory holes drilled in the butterflies so they will have to be plugged and re jetted in order to use it on a dual carb setup.
http://images.thesamba.com/vw/classifie ... 135536.jpg
THIS ITEM HAS BEEN SOLD/
Re: 40mm IDF Center Mount Carb Complete Assembly
Post by Piledriver » Sun Mar 08, 2015 5:24 pm
That looks like the "good" center mount setup with a decent heat riser setup.
A great deal for someone if they use the heat risers.
(the only way it will work well, unless you live where its >100F all the time, and even then...)
A pic of the backside of the manifold showing how the heat riser passage goes all the way to the carb base is in order.
videoguy009
Re: 40mm IDF Center Mount Carb Complete Assembly SOLD! SOLD!
Post by videoguy009 » Fri Mar 20, 2015 8:48 am
Everything is in order for sure.Only used for one year.Will get pic tomorrow.
Last bumped by videoguy009 on Fri Mar 20, 2015 8:48 am.
