New TRW T1 steering box
markvwguy
Post by markvwguy » Mon Apr 17, 2017 8:01 pm
Does anyone know if the T1 steering box comes filled with gear oil? Or do I have to fill it?
Also, This one at center position has a detent, where there is a noticeable notch at center. Is this normal for the TRW box?
My Last new steering box was for last Bay window bus and I had to fill it.
Thanks,
Mark
Re: New TRW T1 steering box
Post by Ol'fogasaurus » Mon Apr 17, 2017 9:41 pm
The last TRW box I bought was filled with a liquid and that was years ago but there should be a plugged fill hole you can carefully open and check to see if it is filled.
The notch is a relief for the bolt that clamps the adapter for the "rag joint" to the mating splined part that the steering column to clamp/attaches to.
markvwguy
Post by markvwguy » Mon Apr 17, 2017 9:46 pm
Thanks, Ol'fogasurus I will check.
