Shock valving bible and dyno charts (Ohlins supplied)
Post by Piledriver » Mon Sep 05, 2016 6:58 pm
Edited the thread name to reflect contents better.
I wish every shock manufacturer posted info like this...
http://www.resuspension.com/assets/Ohli ... 20Book.pdf
Sadly doesn't cover ring shims and bypass shims etc, but its comprehensive otherwise.
(EDIT:It actually DOES cover ring shims usage well, missed that on the first scan through)
Is there a document for the various FOX or Bilstein shock pistons and std shim stacks like Ohlins publishes?
Seems a very sensible way for racers to see what they are ordering.
Its too bad Ohlins parts cost like jewellery, but its likely a "you get what you pay for" situation.
Re: Shock/damper piston vs shim stack dyno graphs
Post by Piledriver » Fri Sep 09, 2016 8:07 pm
Everything you ever wanted to know about valving shocks but didn't know where to even begin:
It nominally covers a specific uber top end shock but if you read through it, it's basically ~a "Shocks 301-302" course..
https://www.ohlinsusa.com/files/files/I ... ual_p1.pdf
