Rear seal replacement
I have a '67 type 1 swing arm and am in the process of replacing the seals in the axles.The question is with the seal seated in the bearing housing how much room is there between the seal and housing for the oil slinger.Is this suppose to be a tight fit,there seems to be at least an 1/8"in mine.The seal went in without any mechanical press,etc.Any info will be appreciated.
