Identifying Transaxel Type and Year
Moderator: Henryhoehandle
VW Bug Buggy
Post by VW Bug Buggy » Sat Nov 19, 2016 11:25 pm
Hi All
I'm new to the forum - I have a VW Transaxel Case (no axels) serial Code: AH 4797345
I am trying to identify the year and type (Swing or IRS)
Can someone help with this?
Re: Identifying Transaxel Type and Year
Post by Marc » Sun Nov 20, 2016 3:51 am
"AH" denotes an IRS trans with a 4.125 R&P (and either a .89 or .88 4th) ...and doesn't tell us much else.
If it has 2 drain plugs it's a `69 (early release bearing, held to the 16mm dia cross-shaft by U-clips)
One drainplug, early release bearing, 16mm shaft: `70 ...change from coarse-tooth 3rd & 4th (.89 4th) to fine-tooth 3rd & 4th (.88 4th) in March 1970
One drainplug, late release bearing w/guide tube with 16mm dia cross-shaft, : `71 or early `72
One drainplug, late release bearing w/guide tube with 20mm dia cross-shaft: late `72
Dual-sideplate IRS transaxles like the AH can be converted to swingaxle (and vice-versa) by changing the differential carrier and sideplates. IRS has splined stubs protruding from the sideplates which accept flanges for the CV joints to bolt to; swingaxle sideplates have an opening where the axle shaft goes in, surrounded by six 8mm studs where the axle tube attaches.
sideshow
Post by sideshow » Sun Nov 20, 2016 8:51 am
Serial numbers can really only tell what it might have been, look (pictures), measure, and count are far more useful today.
VW Bug Buggy
Post by VW Bug Buggy » Sun Nov 20, 2016 3:43 pm
Great - thank you Marc for the feedback really appreciate your input - I will confirm and start the rebuild
