Good day Guys,
Does anyone know if there is a 5 speed 091 kit with wide gears.
091 5 speed with width gears.
- Henryhoehandle
Re: 091 5 speed with width gears.
What do you mean by wide gears?
- jsturtlebuggy
VW made a 5speed trans for the Vanagon that has wider gears. The whole trans is longer. I using one in my buggy. I bought a use 091/1 4speed side shifter and converted using to a 094 5speed using parts from Weddle Industries.
The only 5speed conversion of a Bus noscone shift transaxle I know of is, Gene Berg's setup. It based on using 113/002 width gears.
Here is a picture showing the differences in length of a 091, 091/1 4speed, and a 094 5speed trans.
Another option is using a Subaru 5speed using a reversed ring & pinion from http://www.subarugears.com/ Todd also makes a adapter to use a VW engine with the Subaru transaxle.
Joseph
Well i want the box to build a 091 5 speed for my daily driver bug. Does anyone know if the 113/002 gears can hold up to say 300whp - 500whp.
- Pablo2
There's nothing given up with 002 width gears. We've drag raced tons of them with 400+ hp engines, and breakage of any 3rd or 4th gear is extremely rare. There seems no measurable extra life or strength to slightly wider 091 gears.
aka Pablo, gears, Geary
9.36 @ 146 in '86
9.36 @ 146 in '86
Ok pablo. Thank you for the information.
- Henryhoehandle
I agree..I also question how much stronger the 094 gears are as well. Some, of course, but not a huge difference, imo. There is a big difference in strength between the 113/early 002 10 tooth mainshaft versus the late 002 9 tooth. The 9 tooth is a lot stronger.Pablo2 wrote:There's nothing given up with 002 width gears. We've drag raced tons of them with 400+ hp engines, and breakage of any 3rd or 4th gear is extremely rare. There seems no measurable extra life or strength to slightly wider 091 gears.
I don't if I missed something and this is coming from someone who knows next to nothing about these transaxles. I thought the advantage was the full size reverse gear for the off road crowd. The 5 speed and closer gearing would just be icing on the cake. At least that's why I have lusted for one and even know they exist I would think like what jsturtlebuggy has done. Can any one else comment who has done this or knows about this.
Terry
Terry
Terry Lytle
Canada
2180
8.5-1 comp
JE forged pistons
Porsche piston squirters
30mm triple "O"ring pump
Web 86 a
1.4 ratio rocker
MS3 PRO ecu
Mini Cam Sync
LS2 coil
50mm Throttle body
TD04L-13T Turbo
SL-1 Turbo prepped heads
Canada
2180
8.5-1 comp
JE forged pistons
Web 86 a
1.4 ratio rocker
MS3 PRO ecu
Mini Cam Sync
LS2 coil
50mm Throttle body
TD04L-13T Turbo
- Henryhoehandle
Yes, the strong reverse is very good, but most off of the off roaders here do not want the extra length on the 5-speed, so they just use the 4 speed boxes. A lot of them do not even use 4th gear. The extra length is a PITA to fit into a rail buggy chassis.terryly wrote:I don't if I missed something and this is coming from someone who knows next to nothing about these transaxles. I thought the advantage was the full size reverse gear for the off road crowd. The 5 speed and closer gearing would just be icing on the cake. At least that's why I have lusted for one and even know they exist I would think like what jsturtlebuggy has done. Can any one else comment who has done this or knows about this.
Terry
