I bought that on a swap meet and I was wondering what you think of it:
I initaly bought it only because I wanted good spare spider gears, but after looking at it, I have the impression it would be better than an original diff for a small engine combo.
what do you think, would you use it?
Spider gears "holder" instead of super diff
Re: Spider gears "holder" instead of super diff
I believe it's the main workings of the old Beef-A-diff. Generally it's not considered a viable alternative to a Super-Diff. Although it does add the two additional spider gears, they are not adequately supported and thus do little to strengthen the stock diff.
johnL (aka H2OSB)
www.superbeetlesonly.com
johnL (aka H2OSB)
- Henryhoehandle
Yes, you are correct..the old Beef-a-diff. It MIGHT be better then an open 2 spider diff, but I have never actually used one of these.
If I remember correctly, the Beef-a-diff was a fix by guys trying to put Corvair engines against a VW transaxle. Not the stronges thing in the world so it got re-invented into things like the super-diff et al.
A great paper weight and conversation piece but not much else from what I have been told.
- ngobet
ok there is plenty of information on the beef a diff.
Thanks for the help!
