Over on the big board, a guy posts this pic:
http://images.thesamba.com/vw/gallery/pix/1364826.jpg
I see what looks like a neutral switch just beyond the front mount.
http://images.thesamba.com/vw/gallery/pix/1364905.jpg
It appears to be just under the head of the reverse shift rod? I've never seen this before, is this something you've seen?
Strange reverse switch
Re: Strange reverse switch
A neutral or backup light switch would be expected to have two terminals, and this has just one....looks like an oil pressure warning light switch.
It's a little hard to make out in the picture, but it looks like there are a couple of brass plugs in there too....I'm thinkin' someone drilled some holes in the nosecone to get in there to manipulate a jammed-up shift rail, and then used whatever was handy to plug them.
Nothing factory:looks like someone needed to plug a hole,man made or otherwise.
Looking at it again, I think you're right Marc.Marc wrote:....looks like an oil pressure warning light switch.
