Went for a ride without first gear last night and the trans got stuck in neutral. I had to tow strap it home.
Possibly the shift rod bushing? I ran out of time and didn't really have a chance to investigate. Will be digging into it tonight and report back.
1st gear not fully engaging??
Re: 1st gear not fully engaging??
1968 Meyers Manx
Does it seem to be truly in Neutral or might it be stuck in the (non-functional) First? That could happen if the hockey stick managed to cross over to the 3/4 rail and the 1/2 rail drifted aft...internal interlock detents are designed to prevent that, but it can still occur if the rails are sloppy in their bores and/or the end of the hockey stick is worn down.
The stuck in neutral issue wound up being a sloppy old shift rod coupler. back to square one issue of no 1st gear engagement. slotted to pull for a trans rebuild next month.
1968 Meyers Manx
