Autostick to Standard transaxle
Do I need to do anything to change over from the autostick to a standard?
Re: Autostick to Standard transaxle
A donor car would be nice. What year is the car? Early AutoStick chassis were built on a separate production line and lacked the conduit in the tunnel for a clutch cable, making for more work when doing the conversion...but if it's late enough to have the tube, it's a bolt-in operation. Besides the trans & front mount, you'll need the pedal cluster and the correct "manual" oil pump for the engine, which will of course also need a flywheel and the appropriate clutch components to match the transaxle vintage. The AutoStick shifter doesn't have to be changed, but should be for a cleaner-looking conversion. The shift rod in the tunnel is shorter on the AutoStick (and twisted slightly) so if you don't change it you'll need to fabricate a longer shift coupler. The distributor advance curve is less than ideal but it'll work...and the shift pattern displayed on the ashtray will be wrong
http://www.shoptalkforums.com/viewtopic.php?t=48229
viewtopic.php?f=18&t=61771
viewtopic.php?f=18&t=143877
Are you racing?
Scavenging the 3/4 rocker box with the 8mm autostick pump "stage" might work well.
Also, one lister here has used the 1/2 stage as a turbo scavenge stage for years.
If it's in good shape, it might be a keeper or sellable.
"new" pumps seldom fit properly, (loose fit/slide in) causing headaches.
