Redline Shockproof Heavy?
Anyone have any insight? Is it ok to use in a stock trans?
71 Ghia Coupe........For Sale
63 IH Scout 80 (beater)
Re: Redline Shockproof Heavy?
I have not tried it myself. Redline doesn't recommend it for synchro-ring applications - they claim that it's so slick it could impair their action - therefore they don't make any claims regarding its corrosive properties, which is reason enough IMO to avoid it for an ACVW.
Look for a GL-4 rating, like their MT-90.
The current GL-5 lubricants which meet the MT-1 spec are definitely better than any old stock which does not, but you can do better.
Marc wrote:Never use any lube, synthetic or not, that doesn't meet the The American Gear Manufacturers Association (AGMA) rating D-130. Differentials (like the final drive portion of an automatic transmission or the third member of a conventional drivetrain) do not contain synchro rings made of non-ferrous materials so they can use lubricants with a higher amount of extreme-pressure additives; problem is that when these additives break down into sulfurics which corrode the brass in the old transmissions' synchros. Generally this means you need to avoid GL-5 lubes and look for GL-4, but it's getting harder and harder to find. API GL-5/MT-1 is supposedly safe to use in old transmissions if GL-4 is unavailable - GL-4 is still produced, but not too many places bother to stock it anymore. CRC/Stalube still offers GL-4; NAPA and CarQuest have a GL-3/4/5 which should be fine too.
ASTM D-130 is normally run at 212ºF, but to make the test more severe AGMA increased the temperature to 250ºF. ASTM D-130 is used to determine the corrosiveness of a gear oil’s EP additive to nonferrous metals. A polished copper strip is immersed in the 250ºF oil bath for three hours and the EP additive corrosiveness is determined by comparing the strip against ASTM pre-rated strips.
ASTM rates the test strip as: 1 a or b; 2 a, b, c, d or e; 3 a or b; or 4 a, b, c or d.
Ratings of 1 a or 1 b are the least corrosive.
...If I was putting in a synthetic, it'd be Redline MT-90 GL-4 or Royal Purple Max-Gear 80w90 GL-4/GL-5. Royal Purple meets the GL-5 spec but their "Synslide" EP additive is non-corrosive so it's no threat to the VW synchros. Another choice would be Amsoil, I haven't used it myself but it's claimed to be safe for GL-4 applications...
Thanks Marc, had some on the shelf from my old Harley and was wondering.
- Pablo2
I've seen the internals of road racing transaxles that have used Shockproof, and it was not a pretty sight. Yellow, baked on muck everywhere .. a cleaning nightmare.
Shockproof is Redline's attempt to offer a high level of EP protection that their MT-90 and MTL don't provide.
I'd trust this Kendall GL5 over any other oil that I've seen mentioned in this thread .. inexpensive and well tested in older 911 Porsches.
Link: http://images.thesamba.com/vw/gallery/pix/1108417.jpg
aka Pablo, gears, Geary
9.36 @ 146 in '86
9.36 @ 146 in '86
