Because it's really hard to find an "original" torque gauge vw547, what tool do you use as replacement ?
Thanks to all
Patrick
VW547 torque gauge
- Pablo2
Re: VW547 torque gauge
Any 0-30 in/lb torque wrench with memory dial. The 547 is overrated.
aka Pablo, gears, Geary
9.36 @ 146 in '86
9.36 @ 146 in '86
- madman4
Thx Pablo, so the handle of a classic torque wrench isn't a problem to turn ?
- Pablo2
No .. Because we're only dealing in 30 in-lbs max, it's easy to keep the beam in motion for a few turns.
To backstep on my previous post a bit .. the memory dial isn't important, but a large dial that can be read while in motion is important.
The memory isn't even applicable for that operation, as it would give a misreading. Only an in-motion reading is good.
I recently did a comparison between the 547 and a regular beam shape gauge, and found the 547 to be less accurate. The internal spring-loaded action causes spikes in the readings.
http://images.thesamba.com/vw/gallery/pix/1173371.jpg
9.36 @ 146 in '86
9.36 @ 146 in '86
- madman4
yeap when I said classic torque wrench I mean the wrench you show in your photo, with the good range of course and not a "clic" wrench.
So if you turn too rapidly or with acceleration cause misreading no ?
