1978 bus automatic transmission/gear ratio
carlost2
who can tell me the gear ratio on a 1978 vw bus {automatic transmission ?]
Re: 1978 bus automatic transmission/gear ratio
I've misplaced my Type III Bentley manual, but poking around over at theSamba I found the following:
The "NF" 010 automatic transmission used in `76-`79 buses had a 4.09:1 ring & pinion, and a 1:1 high gear.
Other 010 transmissions come with a 2.71 1st and 1.50 2nd, or else 2.55/1.55
Low gear on a Vanagon automatic is 2.71:1, I believe the bus trans was the same.
=> I'm assuming the bus is 2.71/1.50/1.00
560
Thanks Mark, A friend of mine kinda had the same question.
Mike
Mike
Jackpot motorsports
WestyPop
According to Helmut Zeidler:
1st gear 2.55
2nd gear 1.45
3rd gear 1.00
Reverse 2.46
R & P final 4.09
Wasserboxer Vanagon autoboxes got ATF cooler lines and coolers up front. Good for longer transaxle life than earlier air cooled torque converters. Adaptable to earlier baywindow busses also.
J.R.
SoCal
1st gear 2.55
2nd gear 1.45
3rd gear 1.00
Reverse 2.46
R & P final 4.09
J.R.
SoCal
560
Thank you for the info J.R. This helps a bunch. Now on to question #2, Will the auto handle 150 HP mild off-road (sand and logging road's, stock suspension) in a glass buggy???WestyPop wrote:According to Helmut Zeidler:
1st gear 2.55
2nd gear 1.45
3rd gear 1.00
Reverse 2.46
R & P final 4.09
J.R.
SoCal
Mike
Jackpot motorsports
Passatman
Can the ring and pinion from this trans be used in an 091 gearbox.Marc wrote:I've misplaced my Type III Bentley manual, but poking around over at theSamba I found the following:
pablovent
Hi, I read this old post......But I need replace Ring and pinion in my vw westfalia CJ 1977 010 auto trans, in this post appear 4.09??
Any place or another recommendation?
Regards.
Regards.
Steve Arndt
You may be better off finding a good used auto vs rebuilding yours.pablovent wrote:Hi, I read this old post......But I need replace Ring and pinion in my vw westfalia CJ 1977 010 auto trans, in this post appear 4.09??
Regards.
Our shop buys quote a few rebuilt boxes from German Transaxle.
Steve
My Baja Build
My Baja Build
