Doodlin
Posts: 8 Joined: Thu Oct 13, 2005 10:22 pm
Post
by Doodlin » Fri Oct 21, 2005 10:49 pm
Does anyone use special tools and/or technics to remove the 13mm nuts on the intake manifolds (dual port) on bugs? I've tried to loosen mine recently but will have to try harder<g>.
sideshow
Posts: 3428 Joined: Mon Oct 27, 2003 11:00 am
Post
by sideshow » Sat Oct 22, 2005 7:39 am
1/4 drive swivel socket or an open box wrench, nothing special. If it is an issue use japanise 8mm nuts as they take a 12mm wrench.
500LbGorilla
Post
by 500LbGorilla » Sat Oct 22, 2005 7:45 am
I use the 11mm brass ones on dual carbs, because you can get a socket on them easily.
