Here's another:
Installing dual IDF/DLRA manifolds is a major pain, but you can make it alot easier.
I cut a 1.5" hole in the fender well. These give me access to #1 and #3 spark plugs. They also give access to the front intake head studs.
I use special M8 nuts with a 11mm head.
Left to Right: 11mm, 12mm, 13mm
I use a 1/4" drive 11mm swivel socket on a 6" locking extension with a 1/4" rachet. All are made by S/K.
I first mount the carb onto the manifold and then bolt the manifold to the head. The rachet fits through the hole and easily tightens the nut on the stud.
Dual Carb Manifold Installation
- Glenn
Glenn
74 Beetle Specs | 74 Beetle Restoration | 2180cc Engine
"You may not get what you pay for, but you always pay for what you get"
http://www.DasVolks.com
- Glenn
They're steel. I get them from GBE.
Glenn
