What not to do in welding
Moderator: tryout
Jadewombat
Post by Jadewombat » Thu Jan 19, 2017 7:50 pm
OK, this is NOT my work--just figured I'd share this and not really sure where else to park it. The correct way would've been to cut a v-groove with a landing, root passes with 3 spacers about 3/16", and then several hot and filler passes to fill the v and grinding down each time to make sure there's no porosity in the welds.
I have no idea what these guy(s) were doing or thinking here. Aside from the correct welds on the flange (far left) the other rows have no penetration--just blobs sitting on top of other blobs. These manifolds are pressured up on the oil rig to several thousand psi with drilling fluid (mud) on the rig. I wouldn't want to be anywhere near that thing when that happens. Scary stuff.
Re: What not to do in welding
Post by Leatherneck » Sat Jan 21, 2017 2:13 pm
"She looks Hideous" Hey I was no where near that place, I didn't do that!
aircooledtechguy
Post by aircooledtechguy » Thu Feb 23, 2017 2:38 pm
Good Lord!! That guy need to be found and have his tools confiscated, PERMANENTLY!!
Post by Piledriver » Fri Feb 24, 2017 2:16 am
That is no way that was done by a professional welder...
A guy with a Harbor Freight welder, I would accept.
Looks like a failed attempt at crack repair.
Post by Leatherneck » Sat Feb 25, 2017 12:24 pm
Failed attempt at a Crack Pipe more like it, had to be doing drugs.
Post by Piledriver » Sat Feb 25, 2017 1:58 pm
In that case, it looks like a success :lol:
wreck
Post by wreck » Sun Feb 26, 2017 2:17 am
"What do you mean it didn't pass NDT "
I've worked in Aus on gas pipelines for 15 years , first as a LV fitter then switched to hydrotesting , I've never seen anything that bad , I wouldn't even use that for the intake of a pump let alone on the pressure side.
looks like a cleaner on nightshift had a go at burning a few rods . no one around to even set up the welder .
aircooledtechguy
Post by aircooledtechguy » Mon Mar 27, 2017 11:13 am
:lol:
I did NDT for 12+ years in the Navy and that bird poop wouldn't even passed the visual before I even bothered setting up my gear for an NDT!! :lol:
nsracing
Post by nsracing » Sat May 13, 2017 9:35 pm
Just because it is ugly does not mean necessarily bad. Looks like the prep was poor..gap/kerf too big and tried to fill it? Not sure what is going on. But I do agree, the weldor could have done a better job. Maybe he/she was too lazy to make an adjustment on the welder or just did not do thin pipings. Who knows.
Looks like he/she was not even wearing a helmet to see what the weld puddle looks like.
