So this is annoying. I'm breaking down this old crank to get the hardware. And this key won't budge.
I've tried to knock it loose with a punch applied to the end, tapping downward on each end and grabbing it with vice-grips. No Joy.
The crank is probably still good so I've been avoiding heat for the moment.
I am thinking about drilling holes in the key until I can crush it where it is.
Thoughts?
Max
Stuck Woodruff key
- Devastator
Re: Stuck Woodruff key
Drill and tap a hole right in the middle of it, then run it out with a screw. Conversely, you could drill and tap it shallow and use the screw to pull it out.
Devastator's Build Thread
Sandrail
going fast enough."
Mario Andretti
Sandrail
going fast enough."
Mario Andretti
- sideshow
I always leave that key in place when removing the gear, after all it is installed before the gear.
- Max Welton
Yeah, I realized my mistake today driving to work. Good thing I don't do anything important for a living.
Max
Max
Devastator's trick will work, you may have to file the first few threads off of the screw since it'll be hard to thread the key all the way through.
If the key is too hard to drill/tap, use a small cutoff wheel on a Dremel to slice it lengthwise (of course you should try to avoid overcutting into the crank, but it's not a big deal if you nick it). Use a large pair of diagonal cutters to squeeze the key together and lever it out like you would a cotter pin.
- Max Welton
Got it. The key was easy without the gear in the way.
Max
Max
Max i destroyed my gear pulling it like that
- Max Welton
Really? How?
It worked fine for me...
Max
Max
I've got a 5 gallon bucket of `em
I always use a puller plate, but that's more to keep from damaging the bearing. I can see how the teeth might need attention with a jeweler's file after yanking the gear off with a 2- or 3-jaw puller, but if it got "destroyed" it was probably too tight a fit to want to reuse anyway.
