http://www.grainger.com/Grainger/weld-s ... alog/N-8k7
I haven’t heard anyone talk about weld studs (capacitive discharge – welding) here so I thought I would bring it up; the URL shows some of the styles but not all of them. They are used a lot for panels and things like boxes. There is a type of weld stud besides the threaded type that is shaped like a bunch of bubbles up and down the stud and they used a spring clip type of mating part that is a push-pull installation.
Stud welding/welded studs
Re: Stud welding/welded studs
Hey Lee , we have a stud gun welder at work but i havnt played with it very much .I think it welds up to 1/4 in studs .We rent it out to an astrailian fellow that travels here and he realy likes it . From what i understand the shear wieght of a stud like this is not very good.the shipyard uses the type that you have to drill a pilot hole for ( mainly for small electrical boxes) but this type of stud gun uses the 22 blank cartradge .I havnt seen the type with the bubbles yet .
instant gratification by hard work and determination granted by GODS hands
No, they are more of a tension type of fastener and it seems we used them in gangs. It has been too long since I designed to them so I forget most of the why with the exception for the one push fit I alluded to. Like I said, boxes and I think electrical could benefit from them.
I don't think I have ever heard of the 22 blank method before. You learn something new every day.
http://www.grainger.com/Grainger/wwg/se ... 16014914:s
some other little doodies I remember playing with.
http://www.panduitproducts.com/catalog/ ... G350LH.htm
http://www.bing.com/images/search?q=pan ... tedIndex=0
These are still around as NAPA sells them. The have double stick tape on the bottom. I have one on my buggy engine that has been there for probably 10 years now. I forget just when I put it on.
http://www.bing.com/images/search?q=pan ... edIndex=22
Like to make a nice neat bundle?
http://www.bing.com/images/search?q=pan ... &FORM=IGRE#
Hey Lee check out my build thread ,I have a new pic for you.
