Rain Hats for Carbs
Rain Hats for Carbs
I have cone shaped air filters that I would like to make clear rain hats for any suggestions?
Steve Arndt
Re: Rain Hats for Carbs
Post by Steve Arndt »
Heat drap some plexi over a buck/mold.
Can you explain the terms you are using?
Steve Arndt
Google can do that for you.
heat draping plastic:
http://plastics.inwiki.org/Drape_forming
Thanks Steve
This will work cool. :D
How did it turn out David?
It is on the back burner for now but I will build one. Trying to get the Kadron carb and intake built first. I am running sooooooooooooooo rich I have to change plus every 100 miles or so. Today idling in traffic the plugs fouled I put in this morning. So I have a bigger problem than I thought with this bistard carb.............. no jets available the head on the jets are smaller than the threads on the jets. And yes I tried filing the head off slowly with a file. I need a lathe to cut them down. On the other hand a Kad should be real jet-able in comparison. But I had fun and that is all that matters to me. Making a intake with 2 flanges for a V style 2 cylinder engine is a real challenge you have 4 angles to get right or it will leak. Call me sometime.
Talk to Jeff, he might be able to help. [email protected]
For Webers, bread baking pans work well, I used Bakers Secret loaf pans for ages.
Leatherneck wrote:Talk to Jeff, he might be able to help. [email protected]
He only does VW's, but he is Kool.
