Type 1 DTM accelerator tube
Moderator: Daniel G
Locked
huw'sspeedster
Post by huw'sspeedster » Wed Sep 20, 2006 1:42 pm
The tube keeps moving in the shroud is there an easy in car fix?is it just a jubillee clip behind the shroud?
Bill K.
Post by Bill K. » Fri Sep 22, 2006 4:20 pm
I used a hose clamp to hold a piece of tubing over the accelerator tube on the "front" side of the shroud.
huw'sspeedster
Post by huw'sspeedster » Fri Sep 22, 2006 4:26 pm
Thanks Bill I have started with a P clip above the geabox holding on the back of the tinware for now If this holds it will do for the time being the engine should only be in for a couple of months until my Torquer kit arrives and gets built! Need to run the car until then!
Locked
