Setting 0 lash manton pushrods
Moderator: Daniel G
Locked
Casey79Westfalia
Post by Casey79Westfalia » Mon Sep 18, 2006 8:52 am
Jake,
I have been doing my valve adjustments by tightening a particular valve until I can just spin the pushrod. Problem is my fat little fingers have a tough time getting in there to really tell if it is spinning or if I am just sliding on oil. Any good techniques for setting 0..
Post by MASSIVE TYPE IV » Mon Sep 18, 2006 8:55 am
You can also use the swivel foot adjuster the same way as the pushrod. If either of these spins and you have no lash in the rocker its all good to go at zero..
Casey79Westfalia
Post by Casey79Westfalia » Mon Sep 18, 2006 9:13 am
Ahaaaa!! Thank, should be able to get my stubs to do that..
paul_f
Post by paul_f » Mon Sep 18, 2006 2:28 pm
MASSIVE TYPE IV wrote:You can also use the swivel foot adjuster the same way as the pushrod. If either of these spins and you have no lash in the rocker its all good to go at zero..
Great idea - this will make setting the tappets so much easier!
Locked
