Is it tough to reseal a cylinder head?
- tallqball
I have a buddy that runs a flow lab. He is flowing a set of 46x36 2.0l 914 heads that I will likely sell. They flowed 211 cfm at .55 lift at 28" depression with the intake manifold!
Now that the fixtures are all figured out, thought I'd have him flow the heads on the engine I bought from Ephry.
I know E said it is ready to run, and I believe that, but I'm a tinkerer at heart.
Is it a big deal to reseal the heads after 2,000 miles of run time?
It has HD Type 1 single springs and stock retainers, should these be changed out? It also has stock adjusters with hydraulic spacers, and I do have a set of new 911 swivel feet.
They are 2.0l Porsche heads, 12mm plugs, 48x38 valves. Thanks!
- Ephry73
If you must, then you can always clean the mating surfaces between the cylinder top and the head. Then lap them in place. If you do this, and floow the torque sequences when bolting the heads again, you will be ok.
I have used copper gasket sealer, as per Jake's recommendation, with good results. I didn't take the heads off the engine, and it's not needed, but it will be sweet to know how much those heads flow.
E
E
- tallqball
Jake, if you're interested, I'll send you the flow data when complete. The intake flow curve on the first heads is similar to your LE200.
The exhaust needs to be rerun. I tried using a cobbled header, and it was too small at the port, and had some nasties. So it needs to be rerun with some A-1 stub pipes.
Q
Q
Posting data
I'd like to see some data here. There are too many statements made about info that have no backing. Maybe an excell spreadsheet with some #'s on different engine combos.
What do you think?
What do you think?
Re: Posting data
I have about 1600 pages of them already. I take this very seriously and not only try out everything I can think of, but also document all of it- thats the difference.Riff131 wrote:I'd like to see some data here. There are too many statements made about info that have no backing. Maybe an excell spreadsheet with some #'s on different engine combos.
What do you think?
Re: Is it tough to reseal a cylinder head?
No Big deal, as long as the heads weren't loose and dork up the sealing surface.tallqball wrote: .....Is it a big deal to reseal the heads after 2,000 miles of run time?
Jake recommends CrMo retainers and ground keepers, and the solid spacer set he sells for $24 is a bargain. Also the 8mm rocker studs/nuts etc.. All cheap insurance, replaces a lot of bits that sucked from the factory.
Who did the heads, Ephry?
No worries then, but if the keepers/retainers are really the stock bits, replace them.Ephry73 wrote:The heads were done by Adrian at HFM. Good points here on head resealing.
E
