bus turbo motor
bus turbo motor
Jake,regarding your rat bus, will there be turbo engine kit or turn-key motor available soon? And if so will it be adaptable to the existing or current bus torque motors? I know you've got alot on your plate, just wondering.
Thank you,
Mark
Thank you,
Mark
bus turbo motor
Can't wait to see the dyno results of the turbo, now will this motor be exclusively built just for the powerstroke? Luckily for me January is very realistic in me obtaining a powerstroked bus.
BTW will the powerstroke motors work in the 80-83 vanagons here in CA. Just trying to keep my options open.
Mark
Mark
Please note that the "Pwerstroke" of yesterday and the newest version are drastically different. The older version still works VERY WELL and is still solod in kit form but the new version that I am booking now for complete builds is based on the "Super 2 Liter" platform and solely made possible by the LE series heads that we have not had in the past.
The 80-83 Vanagons are my least favorite of all VW vehicles, the gearing is horrible and they are too heavy. The engine bays are laid out funky and seriously impeded what can be done to the power plant. I do not offer an engine in Turn key form for them. This Turbo engine will be set up for 72-79 Buses only.
As far as California goes, if its a 76 or newer Bus, forget it- there is no way in hell it would make it past the visual inspection!
- Clatter
OOOooo!
I knew it!
LE series for busses! Can't wait!
I knew it!
The LE-160 was primarily developed for Bus apps and super high velocity torque engines.. Like the Super 2 Liter..
http://www.aircooledtechnology.com/le160.htm
bus turbo motor
OK, Jake, or anyone that can relate to this subject, will an automatic tranny (pre '76) hold up to the powerstroke or turbo motor?
- Clatter
Does this mean that you are getting away from using stroker cranks on bus motors?
