I have a 66' that needs the fwd firewall and the driver side heater channel replaced. Which should be replaced first? Once I get done with the pan restore I will be starting the panel replacement on the body. Hopefully just the one channel will be all that needs replaced.
Thanks in advance for the info.
Panel replacement order
For those who understand, no explanation is needed.
For those who do not understand, no explanation is possible.
