Need Rocker Panel measurements!!!
BAJA-IT
Post by BAJA-IT » Mon Apr 04, 2011 4:52 pm
I am replacing the rocker panel/heater channel in my son's '72 Beetle that was hit on the right hand side, this was before he owned the car, and I need to know what the measurement is from the inside to inside of the heater channels at the base of the b pillers. The front and rear quarter panels were both pushed in aswell and will be replaced, so I need this measurement to make sure the car stays square. The heater channel is already removed from the car and I am ready to install the new one, but the front quarter is pushing the back of the rocker towards the center of the car, and I'm not sure where it should be. I had to cut the lower part of the rear quarter off to get the rocker panel out. Any help would be great.
Thanx,
Cameron
BRAT Motorsports #936
Bruce2
Re: Rocker Panel measurements!!!
Post by Bruce2 » Mon Apr 04, 2011 5:55 pm
Exactly the same as the other side.
BAJA-IT
Post by BAJA-IT » Mon Apr 04, 2011 7:03 pm
I need the side to side measurement, LH to RH.
BAJA-IT
Re: Need Rocker Panel measurements!!!
Post by BAJA-IT » Wed Apr 06, 2011 4:41 pm
Nobody has or knows what it should be? I would hate to guess and get it wrong. Somebody must have a body off the pan that can measure this for me.
BAJA-IT
Post by BAJA-IT » Fri Apr 08, 2011 3:09 pm
Got the info I needed from the guys in the Off Road Forum.
BAJA-IT
Post by BAJA-IT » Mon Mar 23, 2015 5:34 pm
Getting back to doing the body work on this car.
Check it out here http://www.shoptalkforums.com/viewtopic ... 8&t=127617
RLFD213
Post by RLFD213 » Tue Mar 31, 2015 6:45 pm
Put the heater channel on the pan and put some bolts in it so its bolts to the pan. Set the body onto it and everything will line up.
