Honest opinion Rustoleum
I'm in the process of building a baja, nothing special just a sweet grocery runner..
Rest of the vehicle will be shot with automotive paint but, to save some dollars do you see a problem, if properly prepared, sanded, wax and grease removed, if I shoot Rustoleum primers and paints in the wheel wells, hood compartment, and engine compartment.. They will be shot with a gun and not rattle canned..
Thanks Bob
Thanks Bob
- namelesswonder
I would do higher quality for wheel wells and engine compartment, as those will be "exposed" to various elements, and your trunk area will not.
However prep work is key, so it could last well enough, but probably not as long as an industral paint.
Franz the Thunder Pumpkin!
Permanent member of the "Baja may not be running" club
- doc
- Site Admin
I've had very good luck with spray can rustoleum on undercarriage parts. As namelesswonder points out, good prep is key. Rustoleum is not as durable as the more expensive industrial encapsulators. If you hit it hard enough, it will chip. Never heard a complaint about POR15, but it's pricey.
Rustoleum will not be show car quality, but it will do a reasonable job. You gotta decide what results you want. Rustoleum is easy, cheap and available at every home center and hardware store.
Rustoleum painted brake parts
Let us know where you come out.
doc
doc
- MNAirHead
http://www.thesamba.com/vw/forum/viewto ... 53&start=0
Here is a great test of alot of frequently used antirust products, the rustoleum does a great job even compared to the high priced products and mind you your car will never see these conditions.
Re: Honest opinion Rustoleum
bump
Last edited by hugging corners on Sat Sep 15, 2012 7:22 am, edited 1 time in total.
- Daniel G
I would just buy a can of Master Series myself..I have tried it and POR-15 and I like masterseries a lot better...
- MinamiKotaro
Use Rustoleum for the entire car. Inexpensive, tough, durable, and looks great. I had people with paint jobs costing thousands of dollars complimenting my Rustoleum paint.
'67 Beetle, 2276
MS-1 v3.57
MS-1 v3.57
Rustoleum sun-fades pretty quickly. I prepped and pained my previous DD with it, and while it looked okay, the paint faded enough in a single year that touch-up paint (from the same batch as the original paint) was noticeable at a glance from a few car-lengths away... and I was painting in sky blue, not a vivid or dark color.
- craigvwdude
Rustoleum as Stray Catalyst pointed out, will fade pretty fast. It just doesn't have quality resins and have UV protection.
There's a reason it's cheap!
If u want some cheap, durable paint for the under side, go to ur local farm supply store and look for some vansickle paint. Its an industial enamal and only runs about $25 / gal in our area
http://i77.photobucket.com/albums/j47/k ... G_3180.jpg
I needed to go cheap and went to the local Napa to check prices on a case of Rustoleum. They said their two-stage paint would be less and would last a lot longer than rustoleum. Once I started working with the Napa brand paint I found how tough it is. I did this three years ago. Now and then I patch chips with an identical color Rustoleum.
kevin
kevin
For areas where finish quality is unimportant (trunk, underside/under fenders) but durability is key, don't forget truck bed liner.
I haven't met a rustoleum product that can take any chemical contact.
Fuel/brake cleaner/brake fluid gets on it--~antyhing, it's done.
It's a shame it can look so good when you do all the prep, but it's the same prep effort for a decent paint that will last, and the PAINT cost difference is really not that huge for most paints.
Having to strip it all off again to paint it properly is the worst part.
