One question though, I have K800 springs, do I have to do something to my pauter rockers? I have heard that you have to make some clearance but is that true?
-MP-
Re: My -54 Ratlook oval
Posted: Fri Jan 15, 2010 3:07 pm
by rgdedge
I have the same Pauter rockers and K-800's on my Autocraft heads. Check the bottom side of the rockers at the spring retainers, I had to clearanc mine just a little because they would rub a little. Use a file or sanding block and take a little off at a time and check your clearances so you wont take too much off.
Tim
Posted: Sat Jan 16, 2010 10:34 am
by SuperTrigger
Ok, thank's for the reply. Have to take closer look.
Posted: Tue Feb 09, 2010 1:32 pm
by SuperTrigger
Some movement again
Short Block ready
Posted: Thu Mar 25, 2010 1:16 pm
by SuperTrigger
Some small update, tank bracket updated, front end wiring almost done.
I must say, you are a wizard when it comes to fabrication.I hope you are well pleased with your progress so far.You have built an amazing machine and I thank you for posting pictures of it.
Posted: Sun Sep 19, 2010 2:20 am
by SuperTrigger
heliarc wrote:I must say, you are a wizard when it comes to fabrication.I hope you are well pleased with your progress so far.You have built an amazing machine and I thank you for posting pictures of it.
Thanks for the kind word's.
What comes to my progress, I'm pleased to what it's now, but not to that fact that it has take so long to get there... and there is lot's of work ahead.
