SOLD
gbaker770
SOLD
Post by gbaker770 »
AS-41 case, 78 Bugpack crank, Berg VW stroker rods, new Mahle 94 mm pistons & cylinders with Teflon buttons, Superflo ported & polished heads, Bugpack intakes, all cooling tin, shroud with 75 amp alternator, Bugpack 1.4 rockers. Engle FK8 cam, Engle lifters, chromoly pushrods, JC pushrod tubes, CB modified 3.5 qt sump, Berg o-ringed oil pump, full flow with remote filter, Garrett T-3 turbo, ceramic coated 1-1/2" header, exhaust, Delta wastegate, Weber 45 mm side draft carb (turbo prepped), Bosch 009 dist. locked out, all braided and an lines for oil and fuel. All fresh with new Silverline bearings, tuned for low boost pump gas, just add race gas and turn up the boost. Run stand time only. Built by a professional, not some hack.
******Also option for Holley 600CFM mechanical secondary carb and DC Carbon fiber intake if preferred******
$4000 OBO
Price Drop $3600 OBO
gbaker770
Re: 2165 CC Turbo Motor For Sale
Post by gbaker770 »
Price change, want it gone $3300.
gbaker770
Post by gbaker770 »
Pending
