EFI EDIS Mega Squirt Stuff for Sale
kuleinc
Post by kuleinc »
$700
This was going to be for converting to EFI and EDIS in my 71 Baywindow, however I am moving onto a Vanagon Westfalia, so I no longer need these items. Picture shows most items in sale.
NOT PICTURED BUT INCLUDED:
-Ford EDIS Coil
-FORD EDIS Module
-Ford VR Sensor and bracket to mount on stock fuel pump location
I actually have double of the above items that aren't in picture and will include the doubles if I can find them in time for shipping.
Most parts were bought from the Dub Shop (Mario Velotta) and are in the condition I bought them in from him, some parts are used. Sold as is. Shipping is actual charge from 94583 to you.
Other items pictured included with sale are:
-Megasquirt 2 with V.3.57 board (I think, its been a while since I bought it from DIY Autotune)
-Relay board
-Relay to MS cable
-Extra wireing kit for a custom harness
-extra wireing kit for custom relay to MS harness
-German EFI Plenum and gasket
-German plenum to end casting extensions
-CB Performance EFI Dual Port End castings, Welded and ported by Steve Tims
-Bosch Idle Valve
-Fuel Rails
-Alternator Strap
-Rebuilt German Throttle Body
-Balanced Aluminum Degreed Type 1 engine pulley with Crank sensor wheel
I ALSO have a German EFI shroud with small oil cooler hole, not included with sale. It needs a blasting and powder coating, but would work GREAT with this plenum as you don't need to drill a throttle cable tube hole in it to line up with the EFI plenum! I will ship everything, except shroud, not willing to ship that, local pickup only, Shroud is extra $100.
I also have a set of TWM Throttle bodies for sale with Fuel Rails, they fit on Webber manifolds: $450 plus shipping.
1995 BMW 318ti with M3 Motor (Mine)
1994 BMW 325i Sedan (Hers)
1968 Baywindow Camper (Parts Bus)
1971 Westy Baywindow (EFI project...)
My build thread: viewtopic.php?f=14&t=137593
kuleinc
Re: EFI EDIS Mega Squirt Stuff for Sale
Post by kuleinc »
Items are all sold.
