head stud pcd
bugtub
head stud pcd
Post by bugtub » Sun Jan 15, 2017 12:05 pm
Apologies if this has been discussed before I have had a searched and cannot find an answer. The Wasserboxer has a head stud spacing of 100mm which is 141.42mm pcd what is the spacing of a type 1 engine
bugtub
Re: head stud pcd
Post by bugtub » Mon Jan 16, 2017 2:52 pm
Had a look at some type 1 heads today, I was thinking they would be equally spaced on a pcd but there not. So I’m guessing that thinking a Wasserboxer is 100mm spacing is also wrong :roll:
Re: head stud pcd
Post by Marc » Mon Jan 16, 2017 4:27 pm
Found this, FWIW: http://ultimateaircooled.com/engines/89 ... ttern.html
One of Rocky Jennings' specialities is modifying cases to alter the stud spacing, he probably has all the dimensions on hand (if not committed to memory)...http://rockyjennings.com/
http://rockyjennings.com/images/shop%20pics%201373a.jpg
bugtub
Re: head stud pcd
Post by bugtub » Wed Feb 01, 2017 5:51 am
thank mark rockyjennings site was one of the first I looked at and if I was closer I would have no hesitation sending my case
