Megasquirt MS2 V3.0 map for 2.1 Wasserboxer
Posted: Mon Nov 02, 2015 3:46 pm
by Rob Habets
Hi,
anyone got a megasquirt MS2 V3.0 for a 2.1 DJ or maybe 2.1 MV engine.
I need it as a starting point to get my engine set up with the K-data KDFI management-system, which is based on the MS2.
Regards, Rob
Re: Megasquirt MS2 V3.0 map for 2.1 Wasserboxer
Posted: Mon Nov 02, 2015 7:53 pm
by westypoo
ill post mine here in a bit, but my map is for a boosted 2.1.
Posted: Tue Nov 03, 2015 4:48 pm
by Rob Habets
Even better, mine's to!
It's a 2109cc turbocharged Oxyboxer based on a 2.1 WBX.
So your map could be a damn good starting point.
Posted: Tue Nov 03, 2015 6:47 pm
by Chip Birks
Hold on a sec...so the only wbx parts are crank and case, but aircooled everything else? Why would you want a wbx tune if your motor is not a wbx? What cam, heads and boost and ignition will you be running?
Posted: Wed Nov 04, 2015 9:25 pm
by westypoo
im going to have to agree with chip here. you do know that tuner studio more or less comes with a map good enough to start the motor on if you know what your doing. with that, you can then just start tuning from there.
