DJ crankcase tapped hole
Im just finishing my 2.1Lt oxyboxer using a DJ case, I dont know what the tapped hole (about 16mm dia) is for ? its situated on the pulley end between oil pump and the filter and directly above the 10mm tapped hole for the engine support bar, and what thread is it? do I just plug it?
- fastback
Re: DJ crankcase tapped hole
stock oil pressure switch sit's there.
a second one is located between the pushrodtubes cyl 3/4
M16 x 1.5.
Just plug it, or put an oil temp sender there.
