Just out of curiosity. Will the distributor out of a 79 2L type 4 fit a type one 1600? If so are they any good?
Thanks
Distributor Question
- sideshow
More of less, they all fit from 25/36hp to Water Boxer. The vacuum can may run into something and the drive pinion (under the fuel pump) may need some adjustment depending on where you want #1 to be.
Great link http://www.oldvolkshome.com/ovhignbo.htm
