remove case savers
Moderator: sparkmaster1
proljoy
remove case savers
Post by proljoy » Sun Apr 22, 2018 3:55 pm
Does anyone know the proper way to remove the case savers?
woodsbuggy1
Re: remove case savers
Post by woodsbuggy1 » Mon Apr 23, 2018 8:45 pm
I removed some a few years ago, first I used a propane torch to heat them to disable the locktite that they should have been installed with, after an hour of cool time I threaded bolts with red locktite into them then let them set over night and threaded them out the next day. If you want to save them you can heat them again with propane torch and clamp between 2 pieces of wood in a vise and they will thread right out.
Good Luck
Kenric
proljoy
Post by proljoy » Sun May 06, 2018 12:19 pm
Thanks Kenric. Just what I needed to know.
