Fuel pump rod tip
Moderator: sparkmaster1
las
Fuel pump rod tip
Post by las » Mon Dec 04, 2017 8:16 am
I'm in the process of turbo'ing my engine and have the fuel pump out, the pump rod in the engine have a sharp ball like tip and the other old one I have laying around have more of a cone and a flat tip.
The flat tip version are a few mm shorter.
I would think the flat tip would be better as it has a bigger surface and therefore distribute the load on a bigger surface!
What would you people think, or what do you know :-)
proljoy
Re: Fuel pump rod tip
Post by proljoy » Sun Apr 15, 2018 1:36 pm
I believe there are two to three diferent push rod lenghs and fuel pumps to match. If you mix them up it will affect the fuel pressure.
Dale M.
Post by Dale M. » Mon Apr 16, 2018 9:16 am
Old school fuel pumps for "generator" engines used a 106mm length pushrod, newer engine with "alternators" use a shorter fuel pump and 100mm pushrod... New short rod fuel pumps also has actuation arm that comes down below the bolting flange...
(Image from J bugs site)
Cant mix and match with out problems...
Dale
Lives his life vicariously through his own self.
