Rocker arm studs won't unscrew
Moderator: sparkmaster1
Post by 84im » Mon Mar 20, 2017 7:38 pm
I'm in the process of installing a set of Pauter rockers on my stock 1600 dual port type 1 engine. I got the old stock rocker studs off one side, but the studs won't move on the other side.
I've used so much force I've started to strip the threads on the double nuts I'm using.
Any hints on how to get these serious stubborn studs out?
Re: Rocker arm studs won't unscrew
Post by Clonebug » Wed Mar 22, 2017 7:48 am
They are probably loctited in.
Take a small torch and heat the stud for a bit to break the loctite grip and it might work
Post by Viva.sabata » Thu Apr 27, 2017 8:18 am
+1. Yes heat, quench with penetrating oil (with lots of ventilation), repeat several times. Then try to bust loose after heating and before quenching. I would use a map gas burner first to avoid over heating. If that doesn't work then try oxy/acety but try to keep it from glowing orange. Keep at it and it will come loose!
