CB HD Springs
Posted: Wed Oct 12, 2016 7:46 pm
by Ark1
Hey guys! Started assembling my heads and the Cb HD springs I installed just didn't seem to fit into the head right. Is it necessary to clearance the base somehow?
Re: CB HD Springs
Posted: Wed Oct 12, 2016 11:25 pm
by Marc
They may be "Chev" diameter which can be used but only after flycutting the spring seat out. Gene Berg used to sell 1.4374" (36.5mm); CB Performance sells some that "drop in" to the stock diameter seat as well as some that they say are 1.440".
Which CB P/N are they?
What retainers are you using, and do they fit snugly into the springs?
Re: CB HD Springs
Posted: Thu Oct 13, 2016 1:43 pm
by Ark1
Cb 1490. Title Reads "1490 Single Hi-Rev Valve Springs - 40hp-later (set of
". The retainers/keepers are the basic chromoly one's offered on CIP1.
Ad says "Replaces original parts perfectly."
I'll grab some picture's of them installed for reference.
Re: CB HD Springs
Posted: Thu Oct 13, 2016 2:47 pm
by Marc
Those should be stock diameter (so "standard" O.D. retainers should fit them fine). OEM springs typically measure around 1.23" O.D., I think the "nominal" size of the stock spring pocket is 32mm (~1.25") - 1¼" O.D. spring shims fit snugly in them.
The inside diameter should come close to rubbing on the guide boss - that'll keep the springs centered, which is why some hacks have managed to fit "Chev" springs to unmachined heads and just let them chew their way in...not smart, especially without a full-flow oil filter
If yours measure bigger than 1.25" O.D. it may be that CBP's supplier made a bad batch and they weren't caught before packaging - you want the retainers to fit snugly, if they can move laterally inside the spring I'd send the springs back.
It's good practice to always use a steel shim between the spring & the head, especially with stiffer-than-stock springs. Doesn't have to be very thick, say .015-.020".
