1955cc cam choice for bus engine? help?
Moderator: sparkmaster1
jimolep
Post by jimolep » Wed Apr 30, 2014 6:29 am
hi guys, im in the process of collecting parts for a 1955cc build for my split. 90.5 b&p 76 crank, scat mini d-port heads 40x37.5 valves, and was thinking dell 40s,but im at a stump as to what cam and lifter combo to go for??
engle 120, 110, and 1.25 or 1.4 rockers?
my last stroker build used a scat c35 witht here lifters, but i always felt it need a few more rpms but then again the heads were 044s, with smaller valves, also on dell 40s.it had good low end torque.
im kind of after somthing thats in the middle ground, has good torque down low, and get stronger as rmp rise.
any ideas guys?
thanks jim
helowrench
Re: 1955cc cam choice for bus engine? help?
Post by helowrench » Wed Apr 30, 2014 7:09 am
I have heads with smaller valves going on the same 90.5X76 and will be using a c25 w/1.25 rockers.
But my intent is a little different, as I am building a limited motor.
Only looking for 90ish hp and all done by 6K is my goal as the wifey's car ends up with this engine, and I have seen her miss a shift (or three).
Phil69
Post by Phil69 » Wed Apr 30, 2014 6:27 pm
If your not too worried about the valve train check out Engle's VZ cams.
BugginPaul
Post by BugginPaul » Mon May 05, 2014 4:21 am
I use eurorace II grind cams in the bus type 4 motors that I build... Generally you want to keep the duration below 280° to keep the torque range down in the lower rpm range :smile:
Phil69
Post by Phil69 » Sun May 25, 2014 12:55 pm
BugginPaul wrote:I use eurorace II grind cams in the bus type 4 motors that I build... Generally you want to keep the duration below 280° to keep the torque range down in the lower rpm range :smile:
Do they do cams for type1 engines?
BugginPaul
Post by BugginPaul » Thu May 29, 2014 9:19 am
I would've thought so... Would have to look into it to confirm!! :)
