I'll try one more time. The reason an ACVW crank, even a short-stroke one, benefits from the addition of the counterweights is not because of balance per se, it's because the two center crankshaft throws are offset to the same side of centerline. If there were two more main journals/bearings this would not be an issue, but since there are not it's only natural for the crank to flex like a jump-rope once the inertial forces overcome the stiffness of the forging. Even a stock Rabbit crank, which does have 5 main bearings, has counterweights because it's designed to run in a higher RPM range than the ACVW was intended for. There is an exception, the short-stroke cast crank used in the 1457, and it does work quite nicely in that application (even though the pistons are the same diameter and if anything are heavier than those used in the 1588) - but that's with a main bearing between every pair of throws, and stiff cast-iron block.Phil69 wrote:Please read this article it may help you change your mind...This engine is still running in a uk street car I believe.
69mm stock Type I crankshaft:
This is a simple, straightforward FACT and I'm not going to "change my mind" about it based upon anecdotal evidence, but since you seem to be overly impressed by stories here's one for you:
The first circletrack class I ever competed in was limited to 1300cc - those pistons are considerably lighter than even the lightest 1600. You can be sure that my engines were dynamically balanced to within a gnat's ass by the most competent machine shop in the region.
Flywheels were restricted to a minimum weight of 16 lbs and counterweights were forbidden.
I ran the tallest gearing of any one competing and still exceeded 6500 RPM whipping around a 1/5-mi track in 2nd with 23" tires (those with "short" gears were buzzing close to 7500). The cases took the brunt of the damage, they'd be pounded out at the center main web to the point of being unserviceable in at most half a season's racing. And yes, shuffle-pins and other "fixes" were all tried with no positive results. EVERY team (at least every one that was running competitive laps) had the same problem.
Most everyone would "move up" after their rookie season to the 3/8-mi track where displacement was upped to 1650cc and carburetion was unlimited - engines turned harder and faster and longer yet they lived because in that class counterweighted cranks were legal. Many teams had a "spare" engine at the ready which was typically built from veteran components and seldom had a CW crank; they were used as a last resort, though, because one 30-lap feature was about as long as they were expected to last. I did build one engine with a stock crank that was used to set a track record (lower windage = more HP), but that was only run for three laps...
