The OG stock pumps were all press on, but also predated the invention of PM (powdered metal) gears...JB17Atita wrote:Is too much bother to ask which pumps had that pressed or keyed gear??
say for example, an OEM 21mm gear pump, is keyed or pressed?
I'm on my way to check that, wish me luck...
Back in the ancient of days they were very much on there to stay, very tight press fit.
What passes for a "stock pump" today is made in Mexico, Brazil or China and almost certainly has pressed on PM gears.
Touch of TIG...
There are several long threads covering the "gotchas" of the pumps currently available, there are many things that can cause the issues you see.
