Thing Gas Tank
VW's aircooled mini SUV. Great for riding in the country, or cruising the beach.
rlowery
Thing Gas Tank
Post by rlowery » Mon Jun 08, 2015 5:59 am
New to the Thing world. Can I purchase a vw beetle gas tank for my 73 Thing without modification?
rlowery
Thing Floor Pans
Post by rlowery » Mon Jun 08, 2015 6:00 am
Can I use a floor pan from a beetle or a ghia for my Thing without modification?
Re: Thing Gas Tank
Post by Marc » Mon Jun 08, 2015 8:18 am
`68-`74 Beetle/'Ghia tank should fit with no modification (early `68 had a weird oval inlet neck, those tanks are obsolete). `75-`78 FI Beetles had a larger outlet line but the smaller pipe/nut from the older tanks will fit them. Through late `73 'Ghias used a balance coil fuel gauge, their senders aren't compatible with the thermal gauge used in Beetles & Things.
Thing floorboards have the same overall shape as those from a `Ghia, but they have different "ribs" stamped in...'Ghia parts will fit if originality's not an issue to you.
http://webspace.webring.com/people/uv/v ... 81_3-4.htm
Busman36
Re: Thing Gas Tank
Post by Busman36 » Mon Jul 13, 2015 4:16 pm
My thing fuel sender and gauge were inaccurate. Indication was a bit over half full when the tank was filled. I finally was able to obtain a new sender. However the indication remains exactly the same. Anything else I can do to get an accurate quantity reading? Is there any kind of adjustment I can make?
Thanks.
Re: Thing Gas Tank
Post by Marc » Tue Jul 14, 2015 12:50 am
Busman36
Re: Thing Gas Tank
Post by Busman36 » Thu Jul 16, 2015 10:58 am
Most informative data on fuel sender and gauge.
