Sneaky Peek of My Latest Motor...
Matt:
It did cure the creeping boost. Better boost control can be obtained by replacing the Cb performance wastegate for something like a larger TIAL wastegate. I have 2 wastegates from CB, so I can always use the original wastegate location to install the additional wastegate. Still I think that the best location is at the header, at the middle of the curve with the outlet looking towards the front of the car. I am aiming for 22 psi. I have run up to 18-20 psi for about 5 seconds with 100 octane. No pinging on 7.5:1 compression. New engine almost together, its a 2332, K8 cam, 42x37 CB supermag heads with large port and polish. 48mm blowthru double dells with large 22X12X3 inches air to air intercooler. Changing air to water intercooler (I will encase it) soon. My aim is 400 plus horsepower, street driven, high 10´s on the quarter mile with slicks.
Can you advise on the carbs jetting using 40mm venturies and 36mm modulator rings. Main jets 1.85, airs 1.60, idles 0.65. What do you think? Are the times and power goal possible? Tranny is fully prepped.
- panel
I think thats pretty impressive using blow throughjrvilledam wrote:Matt:
- volksbugly
Re: Sneaky Peek of My Latest Motor...
Where did you get the air filter. I'm going to be running a plumb back too, but I'm having trouble finding a filter.
Just make it your selfvolksbugly wrote:Where did you get the air filter. I'm going to be running a plumb back too, but I'm having trouble finding a filter.
2165cc on a Borg Warner S257 SXE, DTA S60 on E85.
Boost was created only to make people smile, and make power!
10.626 @ 132mph SCC2016
10.407 @ 134mph SCC2017
10.221 @ 135mph SCC2018
- rubenski
Sweet engine..plans for a dyno?
- Chip Birks
You guys are aware that this thread is 9.5 years old right?
- rubenski
