How not to cool turbo motor
just having a bit of fun with u guys
I'm a little under the weather (had all but 7 of my teeth pulled)
only 20* and we got a light Dusting ,windy 2 days ago, Lost all power(electric) lines down , Tarp blew off the old Rail
so I had to take a pic
Re: How not to cool turbo motor
Point taken I will find a different way to to cool mine
Hope things turn around down there
Terry Lytle
Canada
2180
8.5-1 comp
JE forged pistons
Porsche piston squirters
30mm triple "O"ring pump
Web 86 a
1.4 ratio rocker
MS3 PRO ecu
Mini Cam Sync
LS2 coil
50mm Throttle body
TD04L-13T Turbo
SL-1 Turbo prepped heads
Canada
2180
8.5-1 comp
JE forged pistons
Web 86 a
1.4 ratio rocker
MS3 PRO ecu
Mini Cam Sync
LS2 coil
50mm Throttle body
TD04L-13T Turbo
Is that a Buggy just begging for attention I see under the tarp????
Ever think about turning down the tip of the exhaust so water can't accidentally drip or get blown in?
Peek-a-boo, I see you hiding behind the tree; I see a buggy too!
I'm not peekin behind the tree I'm takin the pic u nut
Yea O'l buggy 'Black Ice ' I use to Race 1/8 mile 7.9@91mph, but all the V8 guys I Beat kept crying it didn't weigh anything,so
I found a steel body Bug and swap the 48 IDA 2332 in it ,an Beat them V8's again the following year then I found the Dragster and NO one wanted to line up next to me
- buguy
That's awesome. That's kind of how I got into VW in the first place. Just out of high school (a looong time ago) I went to Arizona. While I was there I went to the drag strip and there was a guy there with a pink with white polka dots bug. He lined up with these cocky guys with a hopped up Viper. Smoked 'em bad! They loaded that viper up on the trailer and left! So awesome! Had to have one after that!!
good story,, I ended up trading the 'Digger' for the White bug I have now
- kangaboy
madmike wrote: ↑Sun Dec 10, 2017 4:19 am I'm not peekin behind the tree I'm takin the pic u nut
Soooo...you trying to find the right someone to give that tarped buggy some lovin
I promise I would let you take a ride whenever you wanted
Naa, it's a Keeper, My good friend who painted it years ago ask me (U aint just gonna sell it are u? ) He didn't charge me a dime
I does need some TLC ,maybe this summer?
- petew
I hope to see it in person then.
No problem Pete, I'll give you & the wife the 'Nickle Tour' here at the 'Farm' but I'm down to to only six Vw's and only 3 run I just need the Date so I'll be here and not Gallivanting around michigan
