My draw through turbo
Moderator: seabeebuggy
madmike
Re: My draw through turbo
Post by madmike » Fri Sep 29, 2017 8:10 am
Up the idle's but like chip said if it's happy,, it's not an issue
I think i've got 60 and a 55 in mine I'll check later for you
you can mix the up :lol: I even use a F11 & a F7 :shock: :lol:
advinnie
Post by advinnie » Fri Sep 29, 2017 9:36 am
Right now At idle I need both mixture screws to be 1/2 turn out for fast idle but the A/F meter is reading 28.1 witch means lean so your saying forget what the meter is saying at idle just set the mixture up for when I'm on boost?
Cause if I set the mixture up to get a meter reading of 15 the screws are both 2 turns out and BUT there's loads of black smoke at idle and a poop load when you rev it.
Post by Chip Birks » Fri Sep 29, 2017 10:10 am
Your meter sounds like it is completely inaccurate. Where in the exhaust is it located. 28.anything with that meter mean full lean, as in no fuel at all. My bet is that either your sensor is junk, or its located too close to the end of the tail pipe.
advinnie
Post by advinnie » Fri Sep 29, 2017 10:32 am
It's an innovate clamp witch inserts into the tail pipe and the sensor screws into it. I calibrated it in air first and it read 20.6 I think. I will have another go later this weekend with it. What I think is happing is that at 850rpm idle the fuel is filling out of suspension and I'm getting a very lean reading but if I up the idle to 1100 rpm I can get a reading of 14.7 by adjusting the mixture screws. Now at 850 idle I have to basically flood the engine to get a good air fuel ratio but as soon as you open the throttle there's black smoke
Post by Chip Birks » Fri Sep 29, 2017 1:24 pm
Too close to the edge of the tail pipe it sounds like. Do yourself a favor, weld a bung into the downpipe, as far from the open end as you can. Also, why do are you targeting 14.7? Does the car have a catalytic converter that needs hot stoich temps to clean garbage out of your exhaust?
advinnie
Post by advinnie » Fri Sep 29, 2017 1:47 pm
Cause that's what I was told to aim for at idle and 11.3 when on boost. I'm new to all of this so it's a massive learning curve for
What sort I be aiming for when at idle when at WOT (off boost ) and on boost?
Dan Dryden
Post by Dan Dryden » Fri Sep 29, 2017 6:21 pm
Probably the low air speed at 850rpm causing some drop out. Then when you blip the throttle the fuel puddles find their way into the engine, causing the black smoke.
To get a cleaner transition from idle, I think you're going to have to settle for a faster idle speed.
madmike
Post by madmike » Sat Sep 30, 2017 6:06 am
Hey Adam, sorry i didn't get the Jet #'s for u it rained most of the day here, then i forgot :oops: :lol:
advinnie
Post by advinnie » Sat Sep 30, 2017 6:51 am
Dan Dryden
Looks like your right I'm going to have to run a high idle but that's not really an issue
Madmike
That's not a problem mate, I'm in the rain now fixing the bug if I was to wait for the rain to stop on the UK πŸ‡¬πŸ‡§ before working on the bug I will be waiting a long πŸ˜‚
Anyway I've got to fix my header now cause I've come across a small issue and that is when I come on to boost the bugs back end scraps on the road and I've bent one of the exhaust manifold pipes 😑 Never had that problem when it was a N/A engine πŸ˜‚
madmike
Post by madmike » Sat Sep 30, 2017 9:59 am
Here's what I ended up with bare in mind I have a 1915cc and some weird 'turbo' cam ,semi-hemi heads :lol:
70 & 50 idles
F7 with a 160 main and a 190 air
F16 with 170 main & 180 air
quite an abortion :oops: :roll: but seems to work good :lol:
advinnie
Post by advinnie » Sat Sep 30, 2017 10:32 am
Wow that's a right strange combination 😁
Well I've managed to straighten up the manifold (in the rain 😜) and I've also pulled the 55idles and replaced them with 45 and WOW what a difference that has made the idle is smoother, the throttle response is so much better and there's no more black smoke puffing out the exhaust. I was starting to think that the slow throttle response was just a downside to a draw through set up but now it's as crisp as it was when it was just a twin carb N/A engine
Still working on the main jets now witch at the moment are 160
advinnie
Post by advinnie » Mon Oct 02, 2017 5:32 pm
Hi all just an update here the 45 idles and 160 mains seem to be doing the trick I just can't believe how rapid this 1600 bug is now. In 1st & 2nd gear she accelerates like a hot 1600 engine but once she's in 3rd gear she line a rocket, much much fast than my 2276cc motor was 😁
There is just one small problem I still need to sort out and that's how to stop the dam manifold coming of the heat exchanger pipes they keep blowing off
Post by Chip Birks » Mon Oct 02, 2017 9:56 pm
Weld flanges or v-bands on. Watch your boost though. It'll spike once those leaks are taken care of.
Post by Piledriver » Mon Oct 02, 2017 10:09 pm
Until you get around to welding on vbands, you can actually keep things together another way.
I don't have any pictures handy, but strapping boost or slip in exhaust side connections has been done forever, and it can be as simple as 2 hose clamps and a bit of metal strip on either side of the joint .
...of course Google is letting me down finding a leak and its way past my bedtime.
I need my beauty sleep. Badly.
advinnie
Post by advinnie » Tue Oct 03, 2017 12:52 am
I've tried google but am not to sure what this slip on side connectors are ?
Once you wake from your beauty sleep and if you have time could you send a link my be in the tropical UK πŸ‡¬πŸ‡§ we call them something else?
